 Topic: which lights come on with ignition???
TuckerBag
TuckerBag » Sat Mar 31, 2012 8:08 pm
On my MC18, with the engine off and the ignition turned on:
The neutral light will be on (if in neutral)
The oil light will be on for a few seconds and then turn off if oil is above reserve level otherwise it will stay on.
Turn indicators will work if activated
Head/tail lights and full beam indicator light will work if activated.
Brake lights work if activated
Horn works if activated
If powervalve is not in the "low" position, and engine kill switch is set to "Run", then powervalves will rotate to "Low" position.
However, if the TPS wires from carbies are disconnected, and engine kill switch is set to "Run", then the powervalves will rotate to "Hi" position.
