The SPL "dry clutch kit" is complete... nothing else required, although while it's in bits you could add a pushrod seal, but it's not common for them to fail.
The SPL "dry clutch plate kit" simply replaces the OEM fibre plates.
I could add OEM fibre plates to the Marketplace, but I don't think I would be able to do them significantly cheaper. There is absolutely nothing wrong with OEM plates and springs on a stock, or even mildly tuned motor, if you don't want to "upgrade".
