Stephen cover your eyes. I attached a drill and gave it a slow spin up with ignition on and cable pulled and after not long at all oil dripped out the ends of the nipples. Job done and thanks for the tip.
If your looking at this on a search its definitely a good idea to try (if unconventional) as the feed is very slow in nature so you will be spinning that shaft for a while.
