 Topic: MC21 Geometry issues.
das134
das134 » Tue May 08, 2012 1:51 am
Hermit wrote:Actually the fork does look long in that pic. The gap between the front of the lower fairing and the ground seems wide. Also the problem can be exaggerated by having a 120/70 front tyre. A 120/60 would lower the front wheel closer to the floor slightly.
What's your laptime at Ruapuna on the NSR?
Looks like the ZX7R forks are 29" in length as opposed to 28" as MC21 originals (correct me if that is wrong). So what's the easiest answer? Drop the triples by an inch/25mm or so?
Do the original forks sit flush with the top triple? I can get it close to standard then set sag if I have enough info. Anybody?
Unsure of laptimes, that picture was the first proper Ruapuna outing on that bike, and it was wet. But without a doubt in the low 30s Rolling Eyes
