 Topic: what is the bottle on the reed cage for?
nxrsr20
nxrsr20 » Sat Jun 02, 2012 8:56 pm
sparky wrote:Yes the holes were plugged.
today i swapped the reed cage from the spare motor with with boost bottles onto the bike. it helped a bit but not too noticable.
i played around with the bike and for some reason, it only seems to run semi smooth is when i run it without an air filter.
Have you checked your idle circuit is clean and carbs set to factory settings?
