 Topic: Head light
PGM4
PGM4 » Tue Jul 24, 2012 6:04 pm
If the NSR switch is anything like the NC23/29/30 range switch (they look identical) using 2x 55W (dip) bulbs will burn out the headlight switch because it's not designed for such bulbs and is a well-known problem, over on 400greybike site they have a fix which involves binning the switch, modifying the wiring and fitting a relay.
