They tend to be a little rich as standard, but should be totally rideable, taking full throttle from 3000rpm. They are by far the most flexible 250 2-stroke on the market.
The standard carb specs are in the technical section of the main site. Make sure the air filter is clean, and the oil pump adjusted properly.
