cgallant wrote:Curifor wrote:
3 - What does this green connector above the fuel hose do and where does it go? I can't find where to plug it in anywhere.
First thing first. That bracket that is attached to the frame is backwards. The solinoid, and the resistor should be on the front of the spar. There are some parts missing that attach to the other portion of that bracket. That wire connects to the missing air solinoids.
Ok, I know this bike was jetted to run at the track with no airbox. Could that be a reasonable explanation for the missing air solenoid?
Thanks for your help in clarifying this mystery.
Curifor
