 Topic: Float height gauge and oil leak!
Lesviffer750 » Thu Oct 11, 2012 6:30 pm
Mike, if the oil is not used or burnt it dont sound like its coming from inside the engine, you might want to check your oil reservoir is not leaking ie, pipe loose, cracked, etc, if its fresh oil, where else can it be coming from. Worth a try.
