 Topic: Torque settings for NSR500V rear axle
drunkn munky
drunkn munky » Thu Oct 18, 2012 12:25 pm
If it helps identify it i know it fits up to a NC30, all it needed was an inner bearing sleeve to fit the NC hub bearing. Sprocket hub, disc, caliper, wheel (with the correct spacer) all fit fine. Im not sure exactly what but i know the RS250 axles fit although there not a straight forward fit on the NC's.
