 Topic: Heya from New Zealand. 1st post.
Dannyvirk
Dannyvirk » Sat Dec 08, 2012 1:09 am
Heya
I ca'nt find what drives the white bush on the end of the speedo drive located in the left side engine cover. The parts list here shows the
Number #21 44808-KV3-701 Joint Speedometer, Number #22 44830-GS3-000 Cable ASSY. speedometer, but it does'nt show what drives it. I haven't checked it but i suspect there is a gap between the gearbox output shaft and part #22. There is nothing to drive Part #22. The transmission parts list. doesn't show anything on the end of the gearbox output shaft. Thats not there. I might have a go at making something up. It be useful if knew what it looked like. Little help....
The temp gauge as never worked either. I removed the coolant reserve to find the sensor, which was attached to the thermo housing, the plug on the sensor looked fine, i gave the inside of the plug a light filing just incase it was connectivity issue. And clipped the plug back on the sensor, i had expected to find a two pin plug, not just a single wire, i remember seeing two wires going to it on the diagram. Sure enough i found the earthing connection in a different position on the thermo housing ,there was nothing plugged into it, the plug was right next to it, just needed to be reconnected, temp gauge is now a runner.
I'm slowly getting the electrics back to spec., I just want everything to work as honda intended.
cheers
