 Topic: NS475R With Zeeltronic Ignition 82bhp / 46ft/lb's Torque
NS500Racing
NS500Racing » Thu Dec 13, 2012 8:06 pm
I've fitted a Zeeltronic programmable ignition to my big bore NS475 road bike and dyno tested it yesterday it made between 3 - 10 bhp more throughout the rev range and 3 - 5 ft lbs more torque than it's ever done before.
Power runs in 4th gear (the usual gear to check the power) were impossible as the rear tyre was slipping on the dyno's roller so runs were carried out in 5th and 6th gears, it made 81 bhp in 6th and 82 bhp in 5th, with 46 ft lb's of torque (more torque than any of the 2012 600cc bikes are making!) and was hitting peak power much faster than before so now needs higher gearing to make use of the extra power.
I would now imagine with the extra power & being able to pull higher gearing it would be good for between 145 - 150 mph depending on conditions, bonkers !
Will Shrink the graph and post it shortly.
Cheers Ian
