 Topic: NS475R With Zeeltronic Ignition 82bhp / 46ft/lb's Torque
NS500Racing
NS500Racing » Mon Dec 17, 2012 1:07 pm
I've attached the dyno sheet, the blue line shows one of the best curves before fitting the Zeeltronic ignition and the red line with the new ignition fitted. As you can see more power and torque everywhere, what you don't see is between 4500 - 5500 rpm another 10 bhp so not just at mid to high rpm and peaks 250 rpm lower.
When you consider that a good standard NS400R makes 52 bhp at 9500 rpm and the 475 bike now makes the same at 7200 rpm it's pretty good.
Cheers Ian
