If you read the full engine rebuild section in the Workshop, this will give you pretty much all the info you need.
Check the Online Parts Manual for schematics of the engine/complete bike.
These two resources alone should be enough to ascertain what you will require for your particular rebuild.
The HRC 0.6mm gaskets are available in the Marketplace.
We can supply OEM parts if you are struggling to get them from your local dealer. Where are you located?
