 Topic: Ignition Timing
TuckerBag
TuckerBag » Sun Feb 10, 2013 7:42 pm
From PGM-II and onward, separate ignition timing maps for each cylinder were possible.
For PGM-II,... between 1000 and 1800 rpm the rear cylinder timing is retarded compared to the front cylinder to give a smoother idle (when the throttle position is less than 5%)
I will guess that this remained the case for later versions of PGM, but am not sure. I have no experience with the MC28.
This should be easy enough to check with a timing/strobe light.
I am not sure if any of Honda's PGM's do this, but,... I have seen examples where, due to the crankshaft twisting very slightly when under load, one cylinder is slightly advanced compared to the other at certain rev/throttle combinations.
