 Topic: Rear head conversion
wardlaw
wardlaw » Fri Feb 22, 2013 3:36 am
Michael,
No air will be trapped. Once you have filled the rad with fluid, you will have the bike running, blipping the throttle a bit.
You will see air bubbles rising as the water pump circulates the water. Once up to temperature, give it a few more blips, top it up and you are good!
Good luck
