 Topic: Fairing clips and fixings
paul g » Sun Feb 24, 2013 9:16 pm
Personally I would have a look at the online parts manual and price up a set of oem bolts and fixings first, they might not work out much more expensive than pattern and will fit a lot better.
Bear in mind that the oem bolts are shouldered so they bottom out on the mounting bracket to avoid cracking the fairing panels, what you save buying cheap bolts you could soon spend many times over replacing cracked panels.
