And this is easy to understand, around the sea urchin everything the picture which is excavated. (As for truth with just the right OK.) With respect to the picture right (the inner part) the transistor burning with overcurrent, it recognized is that the hole opens? Actually you think that you understand that you make see, but black) when the transistor directly receives the damage it is the majority two green color of the right side (with year system. Speaking conversely, at the time of servo trouble here should have been exchanged, is. By the way the transistor above the RC valve to "LOW -> on the side which is moved HI", direction under to "HI -> is the side which is moved LOW". In other words the RC valve does not move the ま of LOW is the ま, don't you think?, direction above is the 逝 っ ちゃ っ て る is? (^ - ^ As for this picture perfection OUT! It understands that it has burnt, but there is also the breakdown which with appearance does not understand normally, so is. When other than PGM you cannot think, temporarily, don't you think? this should have been exchanged meaning is. That front two is black, it will do quietly being there is no relationship.
That was according to my translator!
Hi and LOW relationships with sea urchins. I thought we were talking PGMs, not sea creatures!
