No. You would need an HRC or aftermarket shock such as Öhlins, WP, or Nitron.
You could try having a new linkage "rocker" machined, but it's not a simple job like with the earlier models [that just use triangular plates], as for a start it would need to be CNC'd. Getting the new geometry even minutely incorrect would seriously effect the handling, and be expensive to develop because of the machining costs. There is also only a very small margin you can work with when modifying the linkage geometry, as it also progressively effects the "rising rate". (Google it!)
