 Topic: Running Without Thermostat
javes
javes » Fri May 24, 2013 5:47 am
The temperature a fan will set on will be very much dependent on how pressurized the system is. I guess our NSRs cooling system works at atmospheric pressure (see the expansion tank plug), but modern engines can keep over 2 bars in the cooling system allowing a higher fluid temp before it boils.
