 Topic: 21 engine in a 28 frame, which chambers do I need?
nxrsr20
nxrsr20 » Fri Jun 28, 2013 8:20 am
Sticking to the normal mantra..... You are deviating from a stock configuration which means it hasn't been set up for that.
I haven't had a 21 and 28 flywheel side by side so I don't know if the pickups are in the same location.
The fact that no one else is commenting means that it may not have been documented before.
