 Topic: MC21 electrical gremlins
Andy » Sat Aug 17, 2013 3:16 pm
Check and clean all the earth/ground points.
Did you replace the reg/rec with a new one, or a used one? That's often quite symptomatic of a duff unit.
It's highly unlikely a PGM problem. The CDI side is very robust; it's only the RC side that's a little fragile, if the power valves aren't maintained properly.
I did however have a failing stator on my MC21 many years ago, and that did cause a similar issue. I would pull the flywheel off and check for a short circuit in one of the windings.
