 Topic: Rear sprocket cush drive bolts
Sprocket nuts
Johnnymac » Fri Aug 30, 2013 7:24 pm
Hi Carl
Carl can you be more precise about this bolt, the bolt that holds sprocket on passes through the alloy carrier into a threaded stud with a hex on that locates in the cushdrive,
I may be able to help with studs not sure about the bolts, let me know I will check for you,
jonmac,
