 Topic: Power valves fully open at 2500 rpm?
Hobbit210
Hobbit210 » Mon Sep 02, 2013 8:38 am
StephenRC45 wrote:The servo motor shouldn't buzz. If you can feel the buzz or hum through your fingers if you put them on the pulley then they are either misadjusted or the cable on one side is too tight.
Thanks, that is what I thought!
So that is with the 'workshop manual' set-up. Would it be best to still use the 'Workshop Manual' (2500rpm) set up but just go for a little more play on the 'tight side' or revert back to the 'TPS unplugged' method?
In my own (tiny??) mind I think that the 2500rpm method to be more correct.
Help please?
Mike
