Just stripped the carb and removed the needle, I then fitted it to the cordless and changed the profile a wee bit.
shortened it by about 2.5mm and adjusted the taper a little. I will now try it at its lowest point as last time the mid range was still to rich, this should put my mid range good and my top end in need of a little more fuel.
The plan is to do this in steps, as it is easy to grind down a needle but not so easy to add some if you get it wrong!
have taken some pics will upload later
