 Topic: Recommended Suspension upgrade 92 nsr250sp
ericandchi
ericandchi » Tue Oct 08, 2013 1:34 am
Check out Race tech in Corona CA. They have a website where you input all your data and it will tell you what setup you need. I just installed a gold valve set and it was just what i needed. I'm 180 lbs so didn't need to change out the springs. If your not up for doing the work they can do it for you. Plus looks like your in CA yourself.
