If you mean the pipes from the pump to the carbs then you can use any plastic or rubber type oil piping. I went for the clear type.
I often use my local bike spares shop http://www.ridersmotorcycles.co.uk/Scripts/default.asp.
The chap that runs it used to import NEW Jap bikes and has a wide knowledge of most things Jap 2 stroke.
Hope this helps.
Mike
