 Topic: Right side fairing lowers - R vs. SE/SP
David_Stack
David_Stack » Tue Apr 15, 2014 7:02 pm
Good Afternoon All;
It appears there is a slight difference between the right side fairing lower for the wet-clutch R models versus the dry-clutch SE/SP models. There is additional material removed from the rearmost 'gill' on the lower for the SE/SP models
See circled area in the SE photo, as compared to the same area on a R.
[img][/img]
[img][/img]
Is there a valid reason for this change between the models, will a lower for a 'R' fit on a SE/SP without interference?
Thank you
r/
Dave
