 Topic: Honda NSR 250 SE PGM 3 MC 21 Problems.
George
George » Fri May 09, 2014 4:31 pm
Hi there
Today i was looking the side stand switch.
I think i found one mistake but who knows so.
There are 3 wires going into the side stand switch
Yellow'Black
Green
Green/White
I check the wiring diagram and see this mistake
Only the Yellow'Black wire was in place on the side stand swtich the other two wires green and green/white was swapped.
Green goes to ground as shown at wiring diagram i check for conductivity between this wire and ground also and to negative terminal of battery and its have strong signal that is good and i plug it in place in the side stand switch so this is done. I was happy to do that its a easy work.
But next other Green/white wire should goes straight into the PGM 3 as shown in wiring diagram and i plug it in place on the side stand switch and when i do conductivity test between Green/White and frame or engine beeping signal comes why is this is right or not?
