I tried fitting the MC21 wheel to my 1992 NF5 and found it wouldnt go straight in. The hub is too wide, possibly due to the sprocket carrier.
If you were to use an NF5 sprocket and the spacer that goes with it, plus some machining it might go in.
Not an simple fit
