 Topic: Power valve and tach issue
Andy » Fri Jun 20, 2014 8:18 am
The black plastic cover just pops off, but it's easy to crack it. It's held in place by a few small raised points that clip into recesses in the alloy housing.
With the cover off, you will see the tops of 4 transistors peering through the epoxy. You need to clean away the epoxy and replace the failed ones.
You should be able to get the transistors from somewhere like Maplin/Tandy/Radio Shack. They are NEC transistors, but I can't remember the number.
