 Topic: bucking at 5.5k RPM
nxrsr20
nxrsr20 » Mon Jul 21, 2014 8:50 am
So what other mods have you done? It will help a lot with diagnostics.
You may have a jetting issue, or the needle shape may not be right. Your jetting may be correct for wide open throttle, not for cruising at a light constant throttle.
If you had stale fuel sitting for a while, clean out your carbs.
