 Topic: Piston and barrel mc28sp
thommo
thommo » Mon Nov 17, 2014 1:36 am
Something major has found its way inside the cylinder.
Looks like you will need a new head and re-lining of the cylinder.
Most likely whatever was in there had made its way out the exhaust.
I would be checking all the intake and in the crank case to see if there is any signs of failure.
Good luck
