 Topic: Are these the correct electrics for NSR250L?
Sly Fox
Sly Fox » Tue Dec 30, 2014 11:14 pm
Hi guys, please can you help me check I have the right PGM and carb solenoid set up for my bike?
I'm assuming that this is a NSR250R7L…..does that mean I should be looking at the 'L' model in the workshop manual?
The reason I'm asking is the 'L' in the manual shows two solenoids and a four way pipe connector.
My bike has one solenoid and a three way connector:
Is this bike supposed to have a gear position sensor and PGM-III?
My GPS has been removed and blanked off with silicon, also it looks as though it was only a neutral switch anyway as there is a single green wire dangling in that area….Also I cannot find anywhere in the loom to plug in a multi-pin socket that a GPS has.
I'm a bit confused because the set up looks more like the "K" in the manual but that has a different frame and swing arm, etc.
Hoping you can shed some light on this and put my mind at ease that my new baby isn't a miss mash of older models.
Thanks in advance!!!
