 Topic: MC21 Track Bike
paul g » Sun Jan 11, 2015 6:53 pm
I plan to use a set of Dogfight exhausts which have been kicking around my garage for years. They are a little bit used so need some repairs, the first issue being the worn manifolds which rattle around in the exhausts like a P**** in a bucket!
Had these nice shiny tight fitting new ones machined up with o-ring grooves.
Issue number two is the silencer mounting flanges which had been drilled and redrilled to accept various silencers with different hole mounting patterns. I ground these off and have had a pair machined to suit Tyga silencers, these are cheap and readily available as I will crash this bike at some point Shocked
Issue number three is the standard dent to the right hand exhaust.
I cut out the damaged area and formed a replacement section.
These are now away being welded.
