cangus wrote:
What size HRC rear best goes with a 3.5" front? Is there a readily available rear wheel...?
HRC started off with a 4.5" option, which you can squeeze a 160 on to if you really have to. But as I already said, you need to work on the suspension (including the ride height), because it's very easy to ruin the handling.
HRC also used a 5" and a 5.5" rear rim.
Readily available?
