 Topic: 17 inch wheels on an MC16?
jeff350lc
jeff350lc » Wed Jun 29, 2005 8:20 am
you could use the R5k arm but its a lot more work. the 16 has no mounting on the frame for the torque arm. the frame is not flat where the arm mounts so you would need to grind away some of the webbing and make up spacers, not a problem on a bare frame, but a lot of extra work if the bikes in one bit still.
