Yuri wrote:
I understan that the dogfighters are not the best on a SP motor . It is just easier to buy once for the end result
That's not what I said, or meant to say, if that's how it sounded, Yuri.
The Dog Fights may not be the best option for YOUR particular setup. What I said was they performed very well on the heavily modified MC21 TT-FIII of StephenRC45's.
Given the chance, we will run several different sets of pipes if we can, and use the ones that give the most desired performance.
In all honesty, I doubt when the difference between TYGAs, Dog Fights, Ethos, HARC Pro, i-Factory, or even most Jha's will be of any consequence to you.
silikesguiness wrote:
dog fights work very well on mine
Yours is finally running now then, is it Si? What does it handle like with those forks?
