 Topic: MC18 oil pump solenoid, how work it?
panchonsr
panchonsr » Sun Mar 29, 2015 8:46 pm
ok bushman, when I get over 7000 rpm valve is switched off ... right? .... so then when you start ignition, the valve should start immediately ... is that correct?....because when i start ignition on, my solenoid valve is no activated....however, the valve is in good conditions....something is wrong....:/
