 Topic: Have I damaged my PGMIII?
cangus
cangus » Thu Apr 30, 2015 10:55 am
My MC21 has an HRC wiring harness for track use. It has no keyed ignition, only the run/off switch. I inadvertently left the switch in the run position for 2-4 days with a battery tender connected. When I realized what had been done the battery was dead, or at least not enough to power up the Koso duel EGT which is switched direct from the battery. after turning the switch to off and charging the battery the bike runs and the power valves work but...with the bike off, if I turn the power valves to high position, when I turn on the ignition the power valves do not return low position, no movement, no noise. They used to just before this incident. My MC18 behaves the same way. Battery has been checked and produces 13 volts without load on it. Have I damaged something???? Sad
MC21R9N track
MC18R2J track
CBR954
CR250
