 Topic: Noisy 6th gear
StephenRC45 » Sun Nov 01, 2015 6:56 pm
Never really see any problems with NSR gear boxes so if youre sure it not a hooked front sprocket or worn chain the only thing that can happen is the output bearing can start to spin in the crank case. This causes some funny noises.
Apart from that pop the box out and have a look. Wet clutch boxes are pretty cheap to pick up or rebuild yours.
