Well I'm back! I managed to get hold of a compression tester! I checked both cylinders cold,as the carbies are off and could get them back on in time! Both cylinders have come back at 76 psi! This sounds low! But is this figure ok for a cold engine! I think that both cylinders coming back the same,seems to be turning me back to carbs! The local mechanic suggests putting the carbies back on and trying a little start aid in the cold cylinder! Any ideas?
Thanks
Tim
