Anyway, not that any of that helps you much, Scott! LOL
The power jets are under the large alloy screws in the float chamber! Use a very close-fitting screwdriver to undo them, as they can be extremely tight, and are easily damaged.
Push the float pivot pin out, remove the floats, and you will see the large alloy screw.
