Gradual failure of speedometer
nine16
Wed May 18, 2016 2:41 am » Post: #1 » Download Post
I have an odd one. While riding this weekend, my speedometer slowly began to read progressively lower. It took about 2-3 hours of riding to get to the point where it now barely registers. Anyone had this happen? Is it fixable or should I just look for a replacement?
Wed May 18, 2016 3:52 pm » Post: #2 » Download Post
If you are talking about mc18/21 with an analogue speedo then my money is on the plastic drive that goes over the gearbox output shaft. The Speedo cable plugs into an angled drive on the sprocket cover that plugs into the white plastic drive that goes over the output shaft.
The angled drive eventually rounds out the slot in the white plastic bit, usually the Speedo works intermitently before it finally gives out.
nine16
Thu May 19, 2016 12:23 am » Post: #3 » Download Post
Yes, it's an MC18R5K. I know the piece to refer to--I'll check it out. Thanks.
cgallant
2001 Honda RS250
Thu May 19, 2016 10:34 am » Post: #4 » Download Post
the other possibility is it could be the part that attaches to the back of the speedometer. It screws onto the speedometer, it could have backed off over the ride.
pkay
Thu Jun 30, 2016 3:43 am » Post: #5 » Download Post
I had this problem when the cable gradually stiffened up and it chewed out teh plastic drive gear. After repalcing both bits and nicely lubed all is good. So when you are replacing the drive check your cable is OK as well.
nine16
Tue Aug 02, 2016 3:58 am » Post: #6 » Download Post
The suggested plastic piece was split. Replaced it and works perfectly again. Thanks.
