New NSR and Grips
NSR peachy
New NSR and Grips
Sat Sep 03, 2016 6:00 am » Post: #1 » Download Post
Hi guys,
New owner of a new NSR250 here. I rescued mine from our showroom which had been sitting there for about 20 yrs. Odo was @ 5 kms but not after my ride this weekend. Smile I'm noticing that w/o a tank grip of sort, I'm sliding forward a lot and the little hanging-off I do is a bit of an effort. What are you guys using? I think tank grips made specific to this bike is not going to be easy to find.... hence i'm asking what you guys have done.
BTW, is it just me or the bike really seems to shifts w/o needing to use the clutch. Am I destroying the tranny by not using the clutch?
I also screwed up and left the cleaner too long on the sticker and as a result it took the clear coat out (wrinkled away) leavig just the red basecoat. You can somewhat see it near the seat. I'm thinking of just getting that repainted and then getting the whole plastic panel repainted.... or if there are stickers to buy still, just pop a new one (same design) on it. What do you guys think?
What's that adjuster on the front suspension do—preload or rebound control? Looks like a preload.
Would I need a steering damper on this? It's completely stock at this point.
Sat Sep 03, 2016 1:56 pm » Post: #2 » Download Post
Welcome to NSR-WORLD! Nice find!! Smile
The adjuster on the "R" model is indeed for preload. "SE" (far cheaper than MC28SP) forks are a direct replacement if you want preload and rebound adjustment. Adjustable SE/SP rear shocks are the same item, and again are a direct replacement for the R shock. The SP shock has preload, compression, and rebound dampening if you want it.
All the stickers are discontinued. You may be lucky and find some NOS (new old stock) stickers somewhere like Yahoo! Auctions, but more than likely you will need to get them remade or have the panel repainted.
NSR peachy
Wed Sep 07, 2016 4:03 am » Post: #3 » Download Post
Any advice on the tank grips or shifting? Smile
NSR peachy
Tue Oct 11, 2016 1:59 pm » Post: #4 » Download Post
I'm thinking of getting the TYGA exhaust kit. Can anyone suggest what else I might need to get w/ this kit? Thinking I might need to replace the stock brake pads and maybe get the larger port airbox.
