NX5 throttle assembly
Page 2 of 2  Goto page Previous  1, 2 Download Topic
TomB
Sun May 14, 2017 6:16 pm » Post: #16 » Download Post
It was my first time out since my high side at Brands, and from the first lap of qualifying, the bike would not rev past 11k. As soon as it got close to 11k, it would cut out- exactly the same as if you accidentally hit the gear lever/quick shifter. I have since removed the quick shifter and measured the coil resistance, to ensure that it's in tolerance. I ran it yesterday, but exactly the same symptoms. So now I'm not sure where to look next. Can it only be the ECU or coils? Or could a cracked wire in the loom be enough to cause this? Open to suggestions!!!
MarkR
Sat Jun 03, 2017 10:47 pm » Post: #17 » Download Post
Have you changed anything since Brands? How old are the plugs/caps?
If it ain't broke, fix it until it is.
TomB
Sun Jun 04, 2017 5:53 am » Post: #18 » Download Post
I ran it on a dyno this week, with the ignition advancer disconnected, and the problem seems to have gone away.So hopefully that's it sorted.
MarkR
Sun Jun 04, 2017 7:53 am » Post: #19 » Download Post
You're not short of toys on your little 250, are you...
Had mine on the dyno last year to check fueling. I'd always joked about summer and winter jets. I've only ever used two combinations.
Turns out they were pretty much bang on.. Surprised
Hope you're all sorted now.
