MC18 Swingarm Question
waynevanrooyen
Mon Aug 21, 2017 5:02 am » Post: #1 » Download Post
Does anyone have an idea as to how thick the MC18 swingarm is, i have some gouges that i want to sand out but dont want to run the risk of going through it.
Fri Aug 25, 2017 7:49 am » Post: #2 » Download Post
I think it's about 5mm. You can see the thickness around the chain tensioners
waynevanrooyen
Sat Aug 26, 2017 9:06 am » Post: #3 » Download Post
Mon Aug 28, 2017 7:06 pm » Post: #4 » Download Post
I would say the part Rob is refering to is the machined axle blocks which are welded to the end of the extruded sections of the swinging arm. I would estimate the extrusions to be no more than 1.5 to 2mm thick so go easy if you are blending damage to these areas.
ian_gt
Thu Sep 14, 2017 7:55 pm » Post: #5 » Download Post
As Paul says, aluminium is only a couple of mm thick so be careful. I had a MC16 one polished, but the deeper scratches remain.
