opinions on new reed valves?
geezagillard
Sun Feb 10, 2019 3:01 am » Post: #1 » Download Post
Just holding my reed cage up to the light I can see the reeds are not sealing on their own....any opinions on whether or not they need replacing
I guess it might seem obvious that they do but I did not know if the primary compression was pushing back form the inside of the motor and causing them to seal anyway?
Not to mention I cant find a part number of the parts fiche so assume Honda wanted to sell the whole block....seems a stretch with such a consumeable part?
prelude2.2
Sun Feb 10, 2019 11:57 pm » Post: #2 » Download Post
i think tyga do carbon reeds
mtec666
Mon Feb 11, 2019 9:34 am » Post: #3 » Download Post
The reeds are avaialble on there own. I ordered and received a set last year, there were fairly cheap too.
geezagillard
Mon Feb 11, 2019 9:54 am » Post: #4 » Download Post
Do you remember how you found the part number mtec666?
Mon Feb 11, 2019 2:19 pm » Post: #5 » Download Post
Reeds only 14111KV3832
Looks like a later part no
geezagillard
Mon Feb 11, 2019 9:26 pm » Post: #6 » Download Post
That helps a lot thanks
So I guess the reeds are the same across the MC18-28..... and only the manifold and stuffer design changed from MC18 to MC21/28?
Sun Feb 17, 2019 9:02 pm » Post: #7 » Download Post
Yes, the reeds are effectively the same for all NSR250s, and most NF5s. As you say, only the rectifiers (stuffers) differ.
Tue Mar 12, 2019 1:29 pm » Post: #8 » Download Post
The reeds not closing will mainly effect the starting and low rpm running.
If they've gone a little soggy then there's a chance of fluttering at high speed, which isn't good.
In the (very) short term you could try flipping them over, but best to replace.
Matt.
geezagillard
Tue Mar 12, 2019 6:12 pm » Post: #9 » Download Post
Appreciate the responses.....thanks
