MC21 SE Crashed and forgotten
Page 2 of 2  Goto page Previous  1, 2 Download Topic
Wed Jan 22, 2020 1:49 am » Post: #16 » Download Post
drunkn munky wrote:
Hmmmm sounds like im gonna have issues with these carbs then. The stock carbs i have are MC18 not 21, is the HRC kit compatible with the 18 carbs as i see the kit is only listed for the 21 on tyga's site.
Everything can be made to work, with enough time, knowledge, and patience. But the stock stuff just works so well with minimal fuss and setup for most people, leaving you reserves of effort for all the other things you want to do. Ultimately, I would say, you want the most reliable setup you can get, so you can pretty much forget about it, and tinker with chassis, brakes, and aesthetics to your heart's content.
The MC21 HRC jet kit is largely compatible with the MC18 carbs. Needles, holders, and jets fit, but the X and Y-pieces (for the PGM-III air correction) are redundant. Given that the MC18 carbs are different, you may need to play with the air correction a lot to get it absolutely perfect, and needle profiles that suit the MC21 carbs may not be optimal for MC18 assembly.
drunkn munky
Sat Apr 10, 2021 12:50 pm » Post: #17 » Download Post
u
ericandchi
Sat Apr 10, 2021 1:01 pm » Post: #18 » Download Post
drunkn munky wrote:u
After 3 months I would have hoped you had more to say on your progress. Very Happy
MC28 SP
