Redistricting mc18
daz680
Redistricting mc18
Sat May 23, 2020 3:31 pm » Post: #1 » Download Post
I was pulling my hair during my build thinking the power valves were not working correctly. Originally the power valves did not move at all, this was sorted with a replacement sub module.
Now working I then went to set them up but they did not appear to be working correctly, if I turned the motor to high manually and then turned the ignition on it just moved to the low position and stayed there, I disconnected th tps and there was no difference.
Started bike and warned up, tried at various revs, still no movement.
Replaced the pgm and the other module and still exactly the same, original Pym and module refitted. Finally I reconnected the black and blue wire by the red plug, low and behold power valves now working and moving to various positions through Feb range.
Now my question is this, if the power valves move to the low position when the black and blue wire is disconnected won't it be even more restricted if the power valves aren't moving at all.
NSR250 MC18 SP, KR1S, TZR250 3MA, RGV250 VJ22P
Sun May 31, 2020 12:54 pm » Post: #2 » Download Post
Is it a 4J or 6K SP?
On my 2J I made the stupid mistake of disconnecting the wire by the PGM, which disables the powervalves. The correct location to pull the wire is at the back in the tail lamp connector
daz680
Mon Jun 01, 2020 11:53 am » Post: #3 » Download Post
Hi Rob
It's a 4J, looks like i made the same mistake
Daz
